Help on GA-1000 Battery Replacement - Not Resetting
Like Tree1Likes
  • 1 Post By Steelerswit
Thread: Help on GA-1000 Battery Replacement - Not Resetting
Results 1 to 6 of 6
    Member jcalka's Avatar
    Feb 2006
    Boston (UTC -5)
    Hi All,
    I have a GA-1000 (5302 Module). A few weeks ago I noticed the flashing low battery alarm in the upper right-hand corner.
    1) ordered two new batteries from PacParts
    2) Replace both
    3) Reset with tweezers shorting AC and cover
    Problem is that while I short the AC to the cover (-) symbol - which actually is positive since the cover touches the (+) of the batteries - the blinking low battery light goes off, but comes back on when I remove the tweezers.
    I have a few G-Shocks and this has never happened. Any ideas? ...something I missed.
    Thanks in advance.
    Breitling Navitimer, B-1 w/ UTC, Ti Avenger Seawolf, Yellow Emergency w/UTC Omega SMPC 2599.80, SM120C 'Big Blue' 176.004, PO 'Pumpkin' 2208.50, Speedmaster 176.0012, Speedmaster X-33 JLC Reverso Grande Date & bracelet Rolex: DateJust, Sea Dweller Panerai 183, 111h, 312 Doxa 750T Pro Anonimo Professionale - Yellow 28/250 UTS 3000m 113/200 Timefactors Dreadnought 125/200 Ball Hydrocarbon Ti "Mad Cow"Helson Sharkmaster Casio GWF-1000, GW-200RB Black Spots, Mudman Rally GW-9010, DW-9000, G2300, GA100-1A1, G7900A-7, GA1000-4A Seiko SBBN007 Tuna, 6138 Bullhead Bradley Mickey Mouse - Circa 1972 Armida A7 Magrette Moana Pacific Pro Vostok-Europe Anchar 8926 Mod Snowflake Vintage VDB 2011
    Feb 2006
    Boston (UTC -5)
    Re: Help on GA-1000 Battery Replacement - Not Resetting
    SOLVED - One of the 'New' batteries was low - tested them on a voltmeter. One old one still had some charge, so it's running until I grab another battery.
    There are no mysteries in life.
    Member Steelerswit's Avatar
    Oct 2016
    South Jersey USA
    glad you figured it out, now
    Quote Originally Posted by jcalka View Post
    odinslostcandy likes this.
    I am responsible for what I say, not your inability to comprehend.
    Hidden Content Hidden Content
    Hidden Content
  4. #4
    Apr 2017
    Hi jcalka,
    I am trying to change the batteries of my GA 1000. However, I am unable to figure out how to pop out the old batteries.
    Please help.
  5. #5
    Apr 2017
    Hi
    I'm having the same issue as ciphershock. hope anyone can help.
    cheers
  6. #6
    Apr 2017
    right so I've found out how to get the double batteries out of my g shock ga-1000. it's pretty much the same as this link, which has a single battery, but you'll see that the clasp that holds down the batteries is the same. i used a safety pin to pry open the battery clasp. it's pretty easy. then just use a little silicone to seal the back up to make it water proof.
    I hope that helps.
    http :// forums.watchuseek. com/f43/how-change-battery-g-shock-19704.html
    Similar Threads
    1. Replies: 2
      Last Post: January 6th, 2016, 11:22
    2. G-1000 (5034) Analog issue after battery replacement
      By ToniCipriani in forum Casio G-Shock
      Last Post: March 28th, 2013, 23:13
    3. Replies: 12
      Last Post: August 16th, 2012, 03:56
    4. Replies: 2
      Last Post: June 10th, 2010, 10:21
    5. Replies: 2
      Last Post: February 1st, 2010, 07:58
