Thread: is the engine in the Tudor Pelagos considered superior engine?
Results 1 to 4 of 4
    Sep 2007
    Question is the engine in the Tudor Pelagos considered superior engine?
    Member roguehog's Avatar
    Dec 2010
    The Tiny Red Dot
    Re: is the engine in the Tudor Pelagos considered superior engine?
    it's a workhorse that's tried and test. superior or not, i think it's subjective. it's a eta 2824.
    I don't have enough watches but I like to talk about them.
    http://roguehogticktock.blogspot.sg/
    Member Drop of a Hat's Avatar
    Dec 2011
    Honestly, wherever there's good pie.
    Quote Originally Posted by roguehog View Post
    I think it's a pretty high grade though. Not your run of the mill 2824.
    But he is correct, it is all subjective.
    Sent via Tapatalk
    (Dedicated to the pink tiger stripe and the man behind it.)
    Watch collector by choice
    Weapons owner by necessity
    In memory of D.K.
    "You gave your life and your dreams so that others could have theirs."
    Hooah kid.
  4. #4
    May 2009
    S F Bay Area
    ETA makes a number of different grades for its movements and Tudor uses the highest grade that can be adjusted to chronometer specs. That's not to make the lower grades to be pieces of junk...except here on the watch forums, the 'normal' watch owner would be hard pressed to tell the difference as the lower grades can also perform very well with proper adjustment and new synthetic lube oils.
