3D printing parts
Like Tree6Likes
  • 1 Post By Raydius
  • 3 Post By Dave S
  • 1 Post By MechaMind
  • 1 Post By Dave S
Thread: 3D printing parts
Results 1 to 8 of 8
    Jul 2016
    Los Angeles, CA
    3D printing parts
    Does anyone have any experience 3D printing watch parts, specifically movement spacers? Trying to gauge whether it's practical to try to go this road in an effort to adapt a movement to a case, or if the tech just isn't precise enough for it to be worth it.
    Sent from my SM-G935T using Tapatalk
    accidentalsuccess likes this.
    Sep 2012
    Leicester UK
    3d printing is good enough for spacers, cases and such. Typical home printers can.manage them. Have a search hereabouts for my lumoholic watch.
    For actual movement parts I think a near net shape would be possible with the latest commercial tech, but it would still need accurate finishing.
    Dave
    Oct 2016
    Re: 3D printing parts
    I use a Makerbot Replicator 2 and I find the resolution fairly limited. It performs well for general geometric shapes and such but is lacking when printing fine details or type below ~9 points.
    I am playing around with printing a positive, creating a silicone mold negative and casting metal filled epoxy for items that require extended wear characteristics with good results. Mind you, this is for production equipment parts and doesn't require anywhere near the accuracy of timepiece movements.
    My printer is about 8 years old and the state of current 3D technology has jumped leaps and bounds since then. I hear that current units ~ $1000 had resolution of about 20 microns!
    Sent from inside a nondescript blue police box sometime in the 21st century...
  4. #4
    Member MechaMind's Avatar
    Mar 2014
    Southern Germany
    I also tried to print cases but found that the material is too inhomogenious to reach a good quality!
    I also think that unreinforced ABS or PLA are much to weak for the daily wear!!
    Therefore I trust in routing!!!
    Raydius likes this.
  5. #5
    Sep 2012
    Leicester UK
    The lumoholic watch is printed in ABS on my reprap Huxley. Its had regular wear for just over a year now and is still fine. I've also printed some trial cases in PLA which also seem plenty tough enough for normal use.
    There are commercially printed metal cases that appear here from time to time, I imagine that they are OK too.
    Dave
  6. #6
    Sep 2012
    Leicester UK
    @webicons - the lumoholic was initially a trial to see if I liked the shape. I then tweaked the cad slightly and scaled it for shrinkage as a pattern for bronze lost wax castings. The craze of 3d printing has forgotten a little that the other name is rapid prototyping -which it is well suited to
    Dave
  7. #7
    Member BRad704's Avatar
    Mar 2015
    Memphis, TN
    I was actually thinking about this to make a spacer for fitting an nh35a into a 7002 case.
  8. #8
    Mar 2014
    Southern Germany
    SUre "printed" SSteel or Titanium will fit the needs but you probably will have to rework the functional areas ans so the effort is not the same ... it is more like a preworked ( rather expensive) stock material!!!
    Similar Threads
    1. 3D Printing and Watch Parts
      By watchkid199 in forum Public Forum
      Last Post: February 15th, 2017, 23:40
    2. 3D printing discontinued parts
      By greengriff in forum Casio G-Shock
      Last Post: September 23rd, 2016, 22:19
    3. 3D printing watchparts
      By trim in forum Watchmaking
      Last Post: January 18th, 2015, 17:44
    4. 3-d watch printing?
      By Brandonu97600 in forum Public Forum
      Last Post: October 2nd, 2014, 16:57
