Parts manual Vostok 2414 movement.
Like Tree9Likes
  • 6 Post By EndeavourDK
  • 1 Post By joaot
  • 2 Post By EndeavourDK
Thread: Parts manual Vostok 2414 movement.
Results 1 to 4 of 4
    Member EndeavourDK's Avatar
    Dec 2018
    Denmark
    On the WRT-forum (thanks to member Watchweasol) I stumbled over two parts manuals; the Vostok 2409 and the Vostok 2414 movements. I placed them in two separate threads respectively.
    I hope these will aid in communication (better description / naming of part(s) where the problem is) and in case you have to order some parts
    24h, Avidfan, borgil and 3 others like this.
    “The more I read & learn, the more I realize how little I know. And even what I think I know, I start to doubt"
    Member Odessa200's Avatar
    Apr 2019
    From now on we will just write ‘part 173 was the issue’ 🙂. Thanks for sharing!!
    Dec 2017
    London
    Re: Parts manual Vostok 2414 movement.
    Thank you for sharing the 2 documents. For someone like me who likes to take movements apart they are very valuable!
    EndeavourDK likes this.
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Dec 2018
    Denmark
    Quote Originally Posted by joaot View Post
    You are welcome
    As comrade Odessa jokingly said with part number 173, it helps to learn & name the parts correctly. Of course using the proper names of the parts clarifies communication and with chronographs (be it Poljot, Omega, Landeron etc) it is common practice to not only use the proper name, but also to mention the correct part number, for example with a Poljot 3133; a Hammer 8220.
    This takes any guesswork out of the equation.
    Suc6 with your endeavours
    joaot and Victorv like this.
