Battery problem with solar/atomic
Like Tree6Likes
Thread: Battery problem with solar/atomic
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Mar 2008
    I bought a GW-300 a few years ago. It worked really fine for a while. Then I put it in storage for a couple of years. I just took it out the other day to start wearing it again. I wore it outside it in the sun for an hour. So I set the time (yesterday) and turned off the receiver (to protect the low charge). I wore it in the sun again today for about an hour. It is still on "low" charge and I can't even use any button within the time mode (such as light or mode change) other than the Adjust button.
    If I take it into Adjust mode, THEN the Mode button does work to navigate around the dial to set everything. But the button doesn't work in main mode.
    What a shame. Do all of them have this problem after a while? I really like this model and the fact that it was cheaper than most solar/atomic models. I don't even care about the atomic feature, but I did like the solar. But I can't believe that it has quit working after two total hours of sunlight which it seems like should have taken it to a full charge, or at least medium charge.
    I don't want to buy another of this model, even though I like the design. Now I'm even hesitant about all their solar models. But I would not mind trying another less expensive solar GShock and finding out the best way to "condition" the battery, assuming that the battery needed some kind of special conditioning.
    Thanks for any information or recommendations.
    ShockMister
    Apr 2013
    Re: Battery problem with solar/atomic
    Perhaps you should expose the watch to the sun for more than an hour per day, for the battery to fully charge.
    Member Mike K's Avatar
    Dec 2011
    Ohio, USA
    There are multiple answers to your problem:
    1) Two hours is NOT enough time to fully recharge your watch's battery. Here's the charging chart from the manual located at http://support.casio.com/storage/en/...009/qw2608.pdf
    Name:  gw-300 charging.png
    2) The rechargeable batteries used in all of Casio's solar-powered models do not do well when they're put in storage for long periods. For best life, they need to be kept fully charged (or at least on "medium.") When they drain to "low" or below, and remain that way for months, they may not hold a full charge again.
    3) As noted in many threads around "f17," a lot of Casio's earliest solar watches seemed to have problems with their battery life, possibly due to the battery manufacturer. It's a relatively common complaint with the GW-300, unfortunately. Casio did address the issue and fix the problem, which doesn't seem to affect most of their later solar or solar/atomic models. (I know, it's a small consolation for the "early adopters" to have been "beta testing" and discovering some of these problems so Casio could fix them for future customers, but as has been noted before, that's a side effect OF the "early adopter" experience.)
    Your EASIEST and first solution should probably be to place your watch outside in the sun, with the display (and solar panel) facing the sun for maximum efficiency, for 18 hours or two days. That should hopefully bring the battery back to a full charge. If you have to place it on a sunny windowsill instead, as the chart shows, that's going to mean leaving it there for 87 hours to get it all the way to "full."
    These batteries have a large reserve -- enough that they can operate in total darkness for months at a time -- but the solar panel itself is usually smaller than a dime, which is spread out around the dial of the watch. That means they take a LONG TIME to charge, but a relatively long time to drain.
    If that doesn't work, you can always replace the battery WITH AN IDENTICAL RECHARGEABLE BATTERY. As long as the charge in the new one is maintained, you should get ten or twenty years of trouble-free operation from it. There are at least three "how to" threads in the Articles and Tutorials section of this forum, or any qualified watch repair shop should be able to change the battery for a fee. Just make sure they know how to work on Casio watches, not lose the multiple small springs inside, and replace it with a RECHARGEABLE battery.
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Mar 2008
    Quote Originally Posted by Mike K View Post
    Thanks. I might have been confusing it with a Citizen dive watch I had that didn't require as much sunlight to charge. I will keep trying.
    ShockMister
  6. #5
    Sep 2013
    South Carolina
    If it has been in storage for years, it will take days to recharge and build up a reserve if you are lucky. If not lucky then a new CTL-1616 may be in your future.
    Casio/ Citizen/ G-Shock/ Pro Trek/ Seiko
  7. #6
    Member Raymond9010's Avatar
    Aug 2013
    Sydney, Australia
    I had a Casio first generation solar watch in storage for years, if my memory serve me correct, it was in storage for close to 7 years, the watch was completely dead, i had to leave it under the sun for a few days on a bright day to bring it back to life, a few hours ain't gonna fully charge it.
  8. #7
    Jun 2011
    Raincouver, BC, Canada
    the G and its battery is fine, 99% sure, just leave it behind your window glass for a week and it will be on duty
    _________________
    Selfishness is not living as one wishes to live, it is asking others to live as one wishes to live.Oscar Wilde
  9. #8
    Sep 2006
    Bay Area, CA
    Samething happened to mine. I believe that there was a batch of bad batteries in them.
    2254.50
  10. #9
    Mar 2008
    Back in business with a Medium level charge!
    I estimate it took 3 hours of outdoor sunlight, plus around 12 hours inside near a window, partially cloudy.
    Now I'm wondering how long it should take to get from medium to high. Or if I should even worry since everything works on it now.
    ShockMister
  11. #10
    Sep 2013
    South Carolina
    Look at the chart in Mike K's post to show how long it will take to "top off".
    Quote Originally Posted by ShockMister View Post
    Similar Threads
    1. Replies: 4
      Last Post: December 30th, 2009, 00:57
    2. CTL1616 Battery in Solar Atomic G's
      By lawrie124 in forum Casio G-Shock
      Last Post: January 10th, 2009, 15:47
    3. Oceanus solar atomic battery life
      By srmdalt in forum Casio G-Shock
      Last Post: April 16th, 2008, 04:41
    4. Oceanus Solar Atomic...battery life?
      By srmdalt in forum Affordable watches
      Last Post: April 15th, 2008, 17:25
    5. Oceanus Solar Atomic...battery life?
      By srmdalt in forum Public Forum
      Last Post: April 15th, 2008, 01:25
