Black Range-man to Olive Range-man, What parts do I need?
Like Tree17Likes
  • 4 Post By GaryK30
  • 1 Post By Knives and Lint
  • 3 Post By Everdying
  • 6 Post By yankeexpress
  • 3 Post By yankeexpress
Thread: Black Range-man to Olive Range-man, What parts do I need?
Results 1 to 10 of 10
    Nov 2010
    Salt Lake, UT
    Question Black Range-man to Olive Range-man, What parts do I need?
    I have a Black Range-man with a positive display. I want an Olive Range-man with a positive display (I don't want a negative display). So, in addition to a Back Range-man, what other parts do I need to order?
    Member sticky's Avatar
    Apr 2013
    South Yorkshire
    Re: Black Range-man to Olive Range-man, What parts do I need?
    I’d be interested in knowing too as I just assumed I’d need a +ve module so if any other parts are needed it’d be handy.
    Member GaryK30's Avatar
    Dec 2014
    Simi Valley, CA, USA
    Quote Originally Posted by Hasaf View Post
    There are two ways to do this.
    1) Buy an olive negative display Rangeman (GW-9400-3) and swap the modules. Doing it this way keeps the golden eye on the olive watch. There is a thread that explains how to do this.
    2) Buy an olive strap and bezel to put on your black Rangeman. Doing it this way you end up with a red eye on the olive watch. This is what I did on the watch I gave to my nephew, because I didn't want to buy two watches to do the "proper" swap. It looks as shown in the pic.
    (Edit - you also have to move the metal studs from the black bezel to the olive bezel, or buy four extra metal studs.)
    Name:  Gulfman GW-9110-1, Rangeman GW-9400-1 olive resin mod (DSC00700).JPG
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Mar 2019
    I guess option 2 is the cheaper option?
  6. #5
    Member Knives and Lint's Avatar
    Jun 2014
    Seattle(West)/Florida(NSB)
    I've also seen a couple of members who've blacked out the yellow lettering on the green resin and even painted the triangle next to the baro button red. It really ties the whole thing together quite well, since red on olive green looks cool anyway and then it matches the eye and crystal lettering.
  7. #6
    Member pl_gristle's Avatar
    Sep 2016
    NY, USA
    I did option 2, easy peasy. Found a band and bezel, like new on ebay for $35. Not sure what prices available now, but check or set up a notification on ebay. One WILL come up. Be patient if necessary, one will come up, maybe try a japan auction.
  8. #7
    Member Everdying's Avatar
    May 2012
    Anfield
    :P
    initially i also wanted to make the G-Shock on the bezel into red...but it was too much work...
    GaryK30, WES51 and Knives and Lint like this.
  9. #8
    Member yankeexpress's Avatar
    Apr 2013
    USA
    M
    None. I did this swap a few years ago, below is the thread link you need to make a proper positive Green Rangeman:
    What you are considering is really a band and bezel swap as opposed to a module swap which requires 2 watches
    What you propose will get you this:
    Positive green with red eye with RED Rangeman
    This is essentially just a black Rangeman with green clothes
    To get a positive green with gold eye and yellow "Rangeman" requires a green watch to get the gold eye with yellow "Rangeman" and a black Rangeman to get a positive screen module. The eye is integral to the case. You need to get a green case.
    Initially I did only the band and bezel swap which was OK until I was encouraged by seeing another member do the module swap and teach us what issues to be careful of when opening a Rangeman and removing the module.
    This thread contains crucial information about what to do to safely swap Rangeman modules. Read from post #42 onward:
    https://forums.watchuseek.com/f17/ra...-948861-5.html
    Today would be a good day to delete your Facebook account:
    Here is why:
    https://forums.watchuseek.com/f73/fa...l#post48047643
  10. #9
    Apr 2013
    USA
    *** be careful opening up this watch. The safest mod is just switching bands and bezels.
    If you decide to open up this watch and switch modules with another Rangeman, there is a ribbon piece that disconnects (unplugs), when that ribbon piece is disconnected your watch module is going read "open". Putting it back You are going need little tweezers to put the sensor ribbon piece back.
    Thread link to make a positive green Rangeman:
    Pfeffernuss, kenls and GaryK30 like this.
    Here is why:
  11. #10
    Jun 2014
    Quote Originally Posted by Everdying View Post
    :P
    Honestly I think that is the perfect amount of red. Looks great and eliminates the issue of not matching, plus it's a fairly no-nonsense solution that fits the watch well
    Similar Threads
    1. Replies: 6
      Last Post: June 18th, 2018, 17:53
    2. Replies: 0
      Last Post: May 26th, 2017, 14:05
    3. SOLD: Black Casio Edifice EF503D...The Poor Man's Speedmaster!
      By ElScorcho in forum Watches - Private sellers and Sponsors
      Last Post: November 13th, 2014, 06:13
    4. Black-case chrono on middle-aged man?
      By Fermenter in forum Public Forum
      Last Post: June 8th, 2014, 17:22
    5. What parts do I need to stealth a g9000-3v?
      By jdiggetydog in forum Casio G-Shock
      Last Post: June 26th, 2009, 17:22
