Building a DW5030C from parts.Help with piezo buzzer
Like Tree18Likes
Thread: Building a DW5030C from parts.Help with piezo buzzer
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Member giorgos mg's Avatar
    Oct 2008
    Hello guys
    Does anyone know where I can get the speaker sticker on a case back?
    I got a Screwback full case as a part but as you see no speaker
    When I attach and hold the back plate from the 5600e and push the button it beeps
    When I screw the case back it doesn't
    Tried to remove the sticker but no luck
    It brakes in small pieces
    Even after heating with a hairdryer
    i contact casio service at my country and they told me that this is not sold as a spare, it comes with the backplate, or caseback
    Can anyone help ?
    Thanks in advance !
    G.
    jringo8769 likes this.
    Oct 2008
    Re: Help with a built project. Need a speaker for Screwback
    This has the 5600e module with 5030c lcd
    So it has the copper look on the screen with blue backlight
    G.
    Oct 2008
    is this what i need?
    PacParts: 91087776318
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Member Mike K's Avatar
    Dec 2011
    Ohio, USA
    Quote Originally Posted by giorgos mg View Post
    Unfortunately, no.
    Casio's "tape/adhesive" is just that -- two-sided tape cut at the factory to a specific shape, usually used to temporarily attach G-Shock pieces together during assembly. Casio often uses it to, say, hold an inner bezel in place to make installing an outer bezel easier, and to keep the inner bezel from falling on the floor if the outer one is removed when servicing the watch.
    giorgos mg likes this.
  6. #5
    Oct 2008
    Thank you very much Mike for the reply
    Will go tomorrow to a store near me
    I might find
    Hoping to update with good news
    Overall I m very happy with the final result
    All it s left it to be fully functional with an alarm
    G.
  7. #6
    Oct 2008
  8. #7
    Member TixTox's Avatar
    Jul 2014
    Atlantis
    That should work. Check the thickness so it is not too thick.
    “Time is an illusion.” ― Albert Einstein
  9. #8
    Oct 2008
    Less than 0.5mm is ok I believe
    If I will not find anything tomorrow I will order these
    Thank you
    This watch is made with parts
    Dw5030c case set from pacparts
    Dw5030c lcd from pacparts
    Gw5000 Band & bezel ,
    spring bars & bezel screws from pacparts
    1545 module, from a beat up used dw 5600e with faded lcd from eBay
    G.
  10. #9
    Member idkfa's Avatar
    Mar 2013
    Vancouver, BC
    Is there a certain current that the speaker needs to draw in order to work?
  11. #10
    Jul 2014
    Atlantis
    Quote Originally Posted by idkfa View Post
    For these it is very low voltage. More important is that is an oscillating voltage or it won't make a sound but that is taken care of by the watch circuitry. The oscillating voltage causes the disc to flex thus making the sound.
    Actually the ceramic disc that makes the sound will also make a spark if squeezed or hit, used to light lighters that don't use a flint.
    Similar Threads
    1. Project 300 - will it be built?
      By americandave in forum MK II
      Last Post: July 26th, 2014, 18:02
    2. Screwback - spring or tab for piezo speaker
      By idkfa in forum Casio G-Shock
      Last Post: June 22nd, 2014, 06:11
    3. Replies: 7
      Last Post: March 28th, 2013, 05:01
    4. Ibamboo speaker
      By blessthisstuff in forum Luxury & Lifestyle
      Last Post: July 5th, 2011, 16:20
    5. Wtb: Custom built metal case for 007 watch project
      By mlax10 in forum WTB - Wanted to Buy
      Last Post: January 10th, 2011, 00:12
