G-3010 Battery change - Having some problems! Help!
Thread: G-3010 Battery change - Having some problems! Help!
Results 1 to 5 of 5
    Dec 2008
    UK
    Dear all,
    I have a working G-3010 that uses a CR2016 battery. It was getting low so I decided to change it.
    I removed the back cover and took out the small spring that makes contact with the buzzer and then removed the battery. Upon replacing the battery I now have nothing displayed on the screen?
    Any ideas? I have taken the whole module apart to see if there is anything visibly wrong but there doesn't seem to be. Is there only the one spring inside the unit or have a possibly lost one?
    Cheers for any help,
    Catch22
    Member Lexxorcist's Avatar
    Jun 2007
    UK
    Re: G-3010 Battery change - Having some problems! Help!
    After changing the battery, did you short the battery with the AC contact for several seconds?
    "The future is something which everyone reaches at the rate of sixty minutes an hour, whatever he does, whoever he is." C S Lewis
    G-Shock & Sales Moderator DragonJade's Avatar
    May 2007
    The land of Casio
    As Lex said, it sounds like you didn't short the AC contact. If you go back to the main G-Shock forum, and go to the top of the page and click on the link to the "How to.." sun forum, there's a thread about changing batteries. All the information you need is in there.
    Get your WUS badge now from the WUS store.
    >> Support WUS by clicking through to our sponsors sites. <<
    >> Buying from a sponsor? Tell them WUS sent you. <<
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Dec 2008
    UK
    Thanks guys!!
    I did the AC short and all is now well.
    Catch22
  6. #5
    Jun 2007
    UK
    That's great. I seem to remember having the same problem with the same watch (it was my first battery change).
