Gshock 2310 parts
Thread: Gshock 2310 parts
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    May 2006
    New Jersey
    Gshock 2310 parts
    Hey gang,
    where could I get a new bezel ad strap for the 2310? It is all messed up from work and it would be great to give it a new lease on life.
    Thanks
    Moderator G-Shock Forum Sjors's Avatar
    Apr 2005
    Netherlands
    Wink Re: Gshock 2310 parts
    Well, usually I look on the pages of Tiktox(worldwide), but if you are in the US you can also look at Casio sales and service(US-Only).
    Cheers,
    Sjors
    There are only 10 kind of people. Those who understand binary and those who don't.
    Bezoek ook eens het Nederlandstalige WUS forum: Kaliber 2010
    May 2006
    New Jersey
    Thanks Sjors. I emailed the Casio sales and service people. I will wait to hear from them.
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Apr 2005
    Netherlands
    Hi Bryan,
    Their email service isn't good (actually they never mailed me back). You better call them by phone. They are located in California. Anyway, if they respond by e-mail to you, let me know, since their e-mail pollicy might have changed.
    Cheers,
    Sjors
  6. #5
    Member cal..45's Avatar
    Jun 2006
    CMOWE (Central Madhouse Of Western Europe)
    @ bryan and sjors,
    how exactly can you change the bezel and strap on a 2300/2310? this two plastic things which hold the strap on both sides (up and down, sorry I don't know the english word for it) are kept by those 4 tiny screws. but even with these unscrewed I couldn't figure out now, how to remove the strap.
    even more difficult I guess, is to remove the bezel, because it seems connected to the case. I admit I haven't got the slightest clue how to remove it, but any helpful information is much appreciated.
    regards, holger
    We are 12.6 %
  7. #6
    Member Resinbandit's Avatar
    Mar 2006
    Greetings All,
    Cal.45 I've never havn't had the need to disassemble mine yet, however I can perhaps wager that it might require a bit of delicate manuipulation?
    That or it may even be a case of using "heat" to remove it.
    I've seen someone use this trick when fixing a starter motor. There was a plastic component which could only be fitted when soaked in warm water.
    I'm sure one of the guys here that attempted a negative display conversion will clear it up for both of us. I'm curious now, as I thought that with this watch I'll replace bezels long before batteries .
  8. #7
    Feb 2006
    Toronto, Ontario
    Quote Originally Posted by bryan
    Hey gang,
    Thanks
    Hey bryan,
    I ordered band and bezel for my mine a month ago through Casio Canada and was told the parts were comming from Casio in New Jersey. The bezel was 18.95 US iirc! Pics below of my heavily abused 2310:)
    Salt build up from a recent 2 week long dive trip
    Damage after a 25 storey drop
  9. #8
    Jun 2006
    hi g-shock,
    since you ordered new bezel and strap, I presume you know how to change them. please share your experiences with us.
    regards, holger
    We are 12.6 %
  10. #9
    Feb 2006
    Toronto, Ontario
    I have not changed the band and bezel as of yet but it seems fairly simple. The band is secured via spring bars which can be removed using precision tools and the bezel is secured via the obvious 4 tiny screws. The bezel screws should not pose much of a problem as the watch is not very old.
  11. #10
    Feb 2006
    Hello there Cal.45,
    to remove the band all you do is remove the spring bars from it. the bezel is held on to the watch by a combo of the 4 screws and also the the fact the bezel is held also on the case from the buttons. to remove remove the bezel
    1. remove all 4 screws on the sides
    2. take a small screw driverand stick it between the underside of the bezel and case and slightly pry on it and allow it to clear the buttons on each side
    3 when you go to put back on remember the buttons turn and if the button is not correct the bezel will not go on.
    G-Shock you are now buying strap and band for the watch you abused and dropped off the CN tower in Toronto????:-D :-D
    Cheers
    Leon
    Similar Threads
    1. FS: NIP Casio GShock 2000 Bezel and Band Set ScrewBack Genuine Factory Japan Made
      By marinemaster in forum Watches - Private sellers and Sponsors
      Last Post: July 10th, 2006, 04:16
    2. FS: NIP Casio GShock 2000 Bezel and Band Set ScrewBack Genuine Factory Japan Made
      Last Post: July 1st, 2006, 04:16
    3. Lemania
      By Airbus in forum Omega
      Last Post: June 24th, 2006, 05:24
    4. What Tools Should Every Begining Hobbyist Have?
      By Isthmus in forum Watchmaking
      Last Post: April 29th, 2006, 16:19
