Questions about GW-9000 Mudman and its parts
Like Tree1Likes
  • 1 Post By JSM1973
Thread: Questions about GW-9000 Mudman and its parts
Results 1 to 4 of 4
    Jul 2013
    Greenville,SC
    Trying to refurbish my old favorite Mudman. However, I've run into some trouble figuring out which part number to order through pacparts. The picture below is the piece I need replaced. There's a screw from one of the straps broken off into the mounts making it so I can't screw in a strap tightly. I went to the pacparts website and am trying to figure out what the part is named. Obviously, I'll need the entire piece which i think is named "case center". Part #91043187580 Would that sound about right to anyone who has replaced theirs?
    Izzy_Does_It likes this.
    Sep 2013
    South Carolina
    Re: Questions about GW-9000 Mudman and its parts
    Yes, if the lug has a screw in it and it can not be removed, then yes, you need to order a case center. $61 and some change? I would also try eBay and look for a beat up model that has a case intact.
    Keep in mind that PacParts will order the part from Japan. It may, yes, may, take up to a month before you receive the part. If you order any other parts at the same time, make sure to mark the order so that all parts will ship to you in one package. If you do not, they will charge you shipping on each item(s) that ship separately.
    BTW, I'm in Lexington, close to Lake Murray. Nice to see another SC member.
    Casio/ Citizen/ G-Shock/ Pro Trek/ Seiko
    Jul 2013
    Greenville,SC
    Thanks. I'm in no rush and my luck with shipping times from pacparts has varied from 1-4 weeks. Thanks again for the assist.
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Member Izzy_Does_It's Avatar
    Apr 2015
    John, your post reminded me to blow the dust off my gal. It's my favorite muddy as well.
    Similar Threads
    1. G-9000 Mudman, Countdown timer questions??
      By bugs in forum Casio G-Shock
      Last Post: December 20th, 2015, 19:11
    2. Battery life questions for my Mudman (G-9000)
      By JoeChristmas in forum Casio G-Shock
      Last Post: December 20th, 2010, 09:44
    3. Mudman G-9000 questions from a beginner!
      By cnj8w in forum Casio G-Shock
      Last Post: December 7th, 2010, 00:44
    4. Casio G-Shock Mudman G-9000-1V G9000-1V G-9000 G-9000-1 G9000-1
      By rahul.creationwatches in forum Watches - Dealers and Manufacturers
      Last Post: December 8th, 2009, 12:12
    5. A Couple GW-9000-1JF MUDMAN Questions
      By Sean123 in forum Casio G-Shock
      Last Post: July 5th, 2008, 05:56
