Solar power on my module 3195 isn't keeping a charge....i think
Like Tree7Likes
Thread: Solar power on my module 3195 isn't keeping a charge....i think
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Aug 2017
    What's up gang....I'm new to this forum, and new to watches....(yeah, really). I just got my tough solar GW 2310 module 3195. I loveit, but I'm nt sure if I'm getting the full capacity of the solar charges.
    How long should I full charge last? I keep the automatic backlight on, fyi.
    Thanks.
    Aug 2017
    Re: Solar power on my module 3195 isn't keeping a charge....i think
    Keep by a window if you will during the day, upload a pic for little help
    Member MainePorsche's Avatar
    Jul 2017
    I'm right here...
    Welcome to the Forum.
    Not sure how long a full charge should last, but will say that AUTO ILLUMINATION will run it down. Are you sure you need that function on ?
    Timepieces
    2017 CASIO G SHOCK GWN 1000H 9AJF
    2017 CASIO G SHOCK GWN Q1000NV 2AJF
    2017 CASIO G SHOCK GWN Q1000MB 1AJF
    ​2017 CASIO G SHOCK GWN Q1000K 7AJR ICERC
    2017 CASIO G SHOCK GWG 1000DC 1A5JF
    2017 CASIO G SHOCK GWF D1000NV 2JF
    2017 CASIO G SHOCK GW 9300DC
    2017 CASIO EDIFICE EF 305 1AV
    1990 ROLEX GMT II M16713LN STAINLESS/GOLD
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Member kcohS-G's Avatar
    Dec 2015
    Quote Originally Posted by 732WatchNewbie View Post
    Thanks.
    welcome and congrats! Your watch will eventually go to "high" charge with daily use. When i got my gw6900, it was on "medium" charge, I got a little impatient so i placed the watch inside a bowl of cold water and let it sit under the sun for an hour. Havent gone down from "high" ever since.
    wcannon32 and CCCP like this.
  6. #5
    Aug 2017
    Quote Originally Posted by kcohS-G View Post
    Good tip, have to remember this.
  7. #6
    Aug 2017
    I'm unable to upload a pic, for some reason.
    I had the watch at a full charge after being outside all weekend. I was surprised at how quickly it went down to medium.
  8. #7
    Member gaijin's Avatar
    Oct 2007
    GMT -7
    When your watch indicates "H" charge level, that does not mean the watch is at full charge - it just means the watch has reached the lowest level of charge in the H range of charge.
    This chart is not for your particular watch, but the principle is the same:
    For the sake of discussion, let's call the Level 3, Level 4 and Level 5 charge levels as "L" state of charge. Then the Level 2 would be "M" and Level 1 would be "H" state of charge.
    When the watch first indicates "H" it is at the borderline between the upper level of "M" charge and the lower level of "H" charge. To reach "Full Charge," the watch needs an additional 5 Hours of outdoor sunlight (or equivalent).
    Your watch went from indicating H down to M so quickly because it was not at full charge. Just continue to charge your watch, even when it indicates H, to fully charge the watch and you will find it stays on H much longer.
    HTH
    "So?"
    -Andrew Breitbart 1969-2012
  9. #8
    Aug 2017
    ok....thanks Gaijin...i'll be patient...
  10. #9
    Jul 2017
    I'm right here...
    What he said ^
    Timepieces
  11. #10
    Member Steelerswit's Avatar
    Oct 2016
    i will add my ditto as well
    Call Sign - Wit
    Si vis pacem, para bellum
    Quote Originally Posted by kubr1ck View Post
    the benevolent caretaker of a halfway house for recovering G-Shocks.
    And the grand rehabilitator strikes again.
    Similar Threads
    1. Mako not keeping charge
      By SuzukiGS750EZ in forum Orient
      Last Post: January 12th, 2014, 18:44
    2. Replies: 5
      Last Post: August 23rd, 2012, 17:50
    3. Moduls 3195 and 3200 - any difference?
      By igorycha in forum Casio G-Shock
      Last Post: April 8th, 2010, 15:52
    4. In power saving mode, will my solar G still charge?
      By dh0licious in forum Casio G-Shock
      Last Post: February 13th, 2009, 03:39
    5. Replies: 10
      Last Post: March 4th, 2008, 22:21
