Problem with water resistance in Flieger? - Page 2
Like Tree56Likes
Thread: Problem with water resistance in Flieger?
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
  1. #11
    Member JacobC's Avatar
    Aug 2013
    Austin, TX
    Quote Originally Posted by stuffler,mike View Post
    Could be an error in handling as well (crown not completely pushed in).
    True. I'm paranoid about crowns around water.....constantly tapping them to ensure they're seated down all the way or screwed in.
    Instagram: open_escapement
  2. #12
    Nov 2009
    Re: Problem with water resistance in Flieger?
    Quote Originally Posted by cadiddy View Post
    I own a new Flieger, washed my hands (may have splashed water on it?) and it had water/moisture inside the watch. Tried everything to get it out, and so resorted to removing the back, which is easy to do. I noticed there is no gasket between the glass back and watch. I also noticed, with the crown open, there's space (not sure how the gasket works on the crown). I contacted Stowa and they said I had to pay to have the watch sent back but the warranty is not good now (watch was less than two weeks old).
    Has anyone else experienced these watches do not have seals/gaskets for water resistance?
    Quote Originally Posted by JacobC View Post
    Seems like an error in assembly. I have some vintage watches RATED for 1 atm that wash just fine including under the tap water in the summer to get gross oils off.
    5 atm should survive full immersion for a few minutes without issue.
    Yes, exactly: "Error in assembly" seems like a very plausible explanation.
    While I take ATM ratings with a big grain of sea salt, a missing gasket between case and back would clearly qualify as that kind of error. Unfortunately, discovering such a missing piece apparently voids the warranty, which is understandable from Stowa's pov I suppose (but IF they did not install the gasket in the first place that is also very unfortunate, as it would be a qc issue which now cannot be addressed fairly to the op).
    I will take it on faith, respect the op, and assume that if he or she is willing and capable of removing a case back he or she is entirely capable of seeing and understanding if a gasket is missing. It is also entirely plausible that a gasket might easily be a misplaced and therefore not installed in a moment of inattention. Probably/hopefully NOT a "common" Stowa problem but who the hell cares...it apparently happened to this particular op/owner, aka the only person who really matters in this discussion.
    To deflect the issue back on the user when that person states, "I noticed there is no gasket between the glass back and watch" does not feel very fair. Alternative notions and defenses such as "it might be user error" might explain IF water penetrated through the crown (although the Flieger Klassik 40mm has no screw-down crown, so not much real protection even if the crown was 100% properly closed) but would not remotely explain a missing gasket, which certainly would also allow more water to penetrate while washing hands than an open crown would.
    That said, op, if Stowa states that the 2-year warranty is now completely voided because you opened the case after 2 weeks, why send it back to them at all? Ask them to kindly mail you either a new gasket or at least the specifications for the proper gasket and then have your watchmaker install it and test. Good luck.
  3. #13
    Jan 2008
    The watch needed repaired for 200 dollars. I owned the watch for a couple of days! It was brand new. I am not really sure what's going on. I got a chance to wear it for a few days, anyway. Jinxed. I am sure they make quality watches. Mine was damaged apparently in transit. Too bad these watches are not robust enought to survive the mail. Very expensive lesson for me. good business model for them.
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #14
    Aug 2015
    Well you should think before you act. You had a NEW watch for 2 weeks and notice water/moisture inside. Every normal user would send the watch back to Stowa for checkup and repair. And since it's under warranty and you didn't do anything wrong (forgot to close the crown,..), repair would be done for free. But no, you decided to open the case...how can now Stowa know what did you actually do with the watch in the first place? Opening the case means warranty isn't valid anymore. Period. If Stowa still decides to repair the watch for free, you should be VERY happy. If not, it's your fault.
    I don't get this kind of people...so you buy a new car, notice a problem with the engine and instead of bringing the car to the dealership, you pull the engine out of the car, can't find the problem and then go to the dealer to fix it under warranty. Really?
    woiter, JacobC and Sebast975 like this.
    Panerai Luminor 0000 Logo
    Laco Leipzig Erbstuck
    Mido Multifort
    Seiko SDGM003
    EMG DL63
    Poljot Aviator IV
    Orient Ray (blue)
    Orient Bambino IV blue
    Helberg CH8
    Casio Tough Solar
    Sturmanskie vintage
    Garmin Fenix 5+
  6. #15
    Aug 2018
    No manufacturer of anything on Earth has valid warranty if you decide to open up their product. Come on now. This one is on you, and I am the first to side with consumers against companies always.
    Sebast975 and platinumEX like this.
  7. #16
    Member whineboy's Avatar
    Aug 2012
    New York City
    Presumably Stowa pressure-tested the watch after assembly, my understanding is that pressure testing after closing the case is standard watchmaking practice. If the gasket was missing I would expect the watch to have failed the pressure test and Stowa would have investigated and taken appropriate action.
    In other words, I don't see how Stowa could have sent the watch out without a case gasket as that would require two mistakes at minimum, no gasket, no pressure test.
    cadenza likes this.
    whineboy
    All mechanical, all the time
  8. #17
    Nov 2009
    I have to agree with Gargamel35, fracture, and whineboy in this case (no pun intended).
    Once one opens the case themselves, all bets/Stowa responsibility are off. They cannot be held to subsequent (or even previous) actions once the watch is opened by a non-authorized person.
    The OP might argue, "But there was no gasket!" to which Stowa could, entirely within their rights, reply, "Did the gasket fall out when you opened the case?". It would be a very legitimate question.
    And, frankly, what does "...Mine was damaged apparently in transit...." even mean, really? By whose judgment?
    To then state, even more absurdly, "Too bad these watches are not robust enough to survive the mail." is insulting, ludicrous, and unfair to Stowa, and so you (op) really lose me there.
    I do not know the numbers but I would assume that, since 2017 marked Stowa's 90th anniversary, more than just a few Stowa watches have survived arduous and tumultuous journeys all across the globe for many years without incident. I know that mine did, extremely well packaged and protected, from Engelsbrand, Germany to Los Angeles, CA, 100% fine. Mine arrived in a standard DHL box iirc, and was certainly not hand-delivered on a bed of fresh roses by a fair-haired maiden riding a pure white unicorn...I would have remembered that, I think. So, perhaps the hyperbole needs to be toned down just a tad?
  9. #18
    Sponsor / Moderator
    May 2005
    Hello everybody,
    this is what i wrote to the customer:
    Dear Mr..........(i delete the name!),
    its me, Jörg Schauer , CEO of STOWA.
    Mr.........., i have to write you because we are trying to find a solution for your watch which is demaged.
    Basicly i am sure that the watch was 100% waterproof when we shipped it.
    Every single watch gets a double check on this specification.
    Even though it can be possible that the watch loose its water resistant during wearing (if it gets a hit or shock at the crown position)
    We don´t know if this or something during the transport happens.
    Fact is, that your watch had condensation like you wrote to us.
    This circumstance can have many reasons - like i wrote - this is difficult to find out.
    You opened the watch by yourself which is basicly a problem, because things can be loose, things can be demaged by doing this and normaly the customer will loose the guarantee.
    (of course it is easily possible to loose a gasket- especially on the caseback after taking of the caseback)
    But i don´t say this like a fact - it might be possible.
    That's not an assertion, but it could have been like this.
    But all this doesn´t solve our challenge we are facing.
    The only way is that we repair your watch and send it back like new.
    Please confirm this and i hope this will help to satiesfied you.
    We will charge nothing for this work because we are sure that you choose the watch in the reason you like it - now you are angry- i understand.
    The reasons we can´t find out 100% - so we will do our best to bring back the satisfaction to you.
    Bye for now
    Jörg Schauer
    CEO STOWA
  10. #19
    Member woiter's Avatar
    Jul 2018
    Vienna, Austria
    Wow! Stowa going above and beyond here.
    Sent from my SM-G970F using Tapatalk
    JacobC likes this.
  11. #20
    Nov 2009
    As one who is all for consumers rights and fairness above all, in general and whether member, "moderator", or company/sponsor on WUS specifically, I have to say that I am becoming increasingly disappointed in the "Problems with abc-xyz watch!!!" threads here on WUS (and I frequent very few forums here).
    There have been at least several very recent threads, regarding both Stowa and Damasko in the cases I read, that start out as, "The sky is falling!", loaded with very negative titles, and then we find out "some details" were omitted by the complainants themselves; and/or that solutions had been provided months earlier to the ops in different, previous threads; and/or that communication with the company had/have already been going on; and/or that the companies were/are in fact doing all they could to resolve the issues in a timely manner...and yet the ops were/are still insistently posting negative claims here, in the public realm.
    I do not know what the solution is, as of course this is a public watch forum, but I also do not feel that every time someone spills coffee on themselves they then have the right to scream about, let alone sue, Starbucks or McDonalds....nor that dissatisfied customers (who may in fact also be at least partially responsible for their dissatisfaction) should paint companies with negatively-titled threads that anyone then searching the internet for, in this case, "Stowa Flieger", might then read.
    I see that Mr. Schauer has had to personally take the time to step in and address marginal-at-best complaints here at least twice now in the past weeks, regarding completely different issues, and has done so as always in his polite and professional manner. Mr. Schauer (and others) has had the class and courtesy to respond elegantly in a thread which title is negative (excessively so?) towards his own company. He has not complained about that, but rather only addressed the "issue" itself straight on, fairly and honestly, with an offer far above any basic responsibility of his. What a headache it must be.
    I truly do hope that posters in the future address their concerns with the same fairness and grace that Mr. Schauer has, with more careful consideration regarding the general impacts of their airing personal "dirty laundry"...and that these public complaints about debatable "problems" do not also become increasingly common as measures by which customers attempt to "strong-arm" companies to provide "more".
    N.B.: before someone specific chimes in, I do feel that this thread (and some similar others) is far different from the "Stowa movements" thread, which addressed a completely different (website-wide description errors versus specific-watch technical "problems") set of issues. The two categories are not at all comparable.
    whineboy, JacobC, woiter and 1 others like this.
