Problem with water resistance in Flieger?
Like Tree56Likes
Thread: Problem with water resistance in Flieger?
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 37
    Jan 2008
    Has anyone else noticed the Flieger does not have 5 ATM water resistance? I own a new Flieger, washed my hands (may have splashed water on it?) and it had water/moisture inside the watch. Tried everything to get it out, and so resorted to removing the back, which is easy to do. I noticed there is no gasket between the glass back and watch. I also noticed, with the crown open, there's space (not sure how the gasket works on the crown). I contacted Stowa and they said I had to pay to have the watch sent back but the warranty is not good now (watch was less than two weeks old).
    Has anyone else expereinced these watches do not have seals/gaskets for water resistance? I now have a German watch I have to take off to wash my hands. Ha.
    Aug 2015
    Re: Problem with water resistance in Flieger?
    Which flieger do you have? I checked my Laco and it's 5ATM (most fliegers from other brands are also "only" 5ATM anyway). And i checked Stowa webpage where it clearly says Flieger is 5ATM also.
    Panerai Luminor 0000 Logo
    Laco Leipzig Erbstuck
    Mido Multifort
    Seiko SDGM003
    EMG DL63
    Poljot Aviator IV
    Orient Ray (blue)
    Orient Bambino IV blue
    Helberg CH8
    Casio Tough Solar
    Sturmanskie vintage
    Garmin Fenix 5+
    Mar 2013
    Somewhere in the 20th century
    Those Fliegers are not water resistant at all. You have to be careful with water activities, including washing your hands. Yes, you have to pay for repairs since that's not covered under warranty.
    For true WR you want a Stowa Flieger Klassik Sport, or Stowa T02, both of which are 200M WR.
    Seeking watch nirvana
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Member woiter's Avatar
    Jul 2018
    Vienna, Austria
    Stowa indicates in their faq that 5 atm should be okay for showering. If you indeed ended up with water inside a 2 week old flieger from washing your hands, that should not be expected. If you explain the situation I would expect they will take care of you.
    Sent from my SM-G970F using Tapatalk
    OnTheRoad99 and GrapeApe like this.
  6. #5
    Mar 2016
    this is concerning; I love the Stowa Flieger with no logo... I hope this isn't common.
    NOMOS Zurich World Timer Blue.
    Tudor Black Bay (Black Bezel).
    Q Timex Reissue.
    Deleted by mod (rules violation)
  7. #6
    Member Mr Auto's Avatar
    Apr 2019
    Quote Originally Posted by bunnswatch View Post
    Me too! I'm on the verge of pulling the trigger on a Klassik 36
    Sent from my SM-N960F using Tapatalk
  8. #7
    Member JacobC's Avatar
    Aug 2013
    Austin, TX
    Seems like an error in assembly. I have some vintage watches RATED for 1 atm that wash just fine including under the tap water in the summer to get gross oils off.
    5 atm should survive full immersion for a few minutes without issue.
    Instagram: open_escapement
    umarrajs likes this.
  9. #8
    Jan 2008
    It's a Klassik 40mm Flieger. Probably my last Stowa. Very disappointed. It's supposed to be 5 ATM.
  10. #9
    Moderator at Large stuffler,mike's Avatar
    Mar 2010
    The Hague-Amman-London-Berlin
    It is not common, of course. Otherwise this forum would be full of complaints, don‘t you think ? The Flieger Klassik 40 is one of the best selling Stowa watches since almost 20 years.
    Kind regards
    Mike
    Instagram @mikestuffler
  11. #10
    Mar 2010
    Quote Originally Posted by JacobC View Post
    Seems like an error in assembly....
    Could be an error in handling as well (crown not completely pushed in). If Stowa assesses an error in assembly they for sure would find a solution to compensate. That however requires to send the watch in. And that‘s what I‘d do in the first place.
    JacobC, briang583 and Sebast975 like this.
    Kind regards
    Mike
