Stowa Antea movement power reserve problem
Like Tree2Likes
  • 1 Post By Nokie
  • 1 Post By terkoko
Thread: Stowa Antea movement power reserve problem
Results 1 to 8 of 8
    Jul 2016
    Hello all,
    I just have a new Antea ks 35.5, but after 2 day I used, 2 problems found,
    1. The power reserve only around 20h, I tried wind the watch to cannot wind, but same, the watch will stop before next day morning, this is my first time using the hand wind watch, how to correct wind? I think full power should be 42h, any special skill?
    2. The watch fast around 10 seconds in 12 hours, it is normal?
    Thank you every one
    Moderator at Large stuffler,mike's Avatar
    Mar 2010
    The Hague-Amman-London-Berlin
    Re: Stowa Antea movement power reserve problem
    Fully wound the pr should be about 44 hrs. However I'd expect seomething from 35 to 40.
    10 secs fast in 12 hrs is way too much.
    Kind regards
    Mike
    Instagram @mikestuffler
    Jul 2016
    Quote Originally Posted by stuffler,mike View Post
    Thnak you for your reply, so not my winding skill problem?
    i think I try more few day, if same I need talk with stowa about this.
    if really the watch problem, stowa will arrange to exchange? Due this is my 1st time shop at stowa
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Member Nokie's Avatar
    Jul 2011
    Northern California
    If it does not settle in, I would contact Stowa to address this issue. Jorg and staff provide great customer service and are very easy to work with when issues arise.
    DummySmacks likes this.
    "Either he's dead or my watch has stopped"
    Groucho Marx
    "The only reason for time is so that everything does not happen at once..."
    Albert Einstein
  6. #5
    Jul 2016
    Today, the 3rd day, the power can keep more than over 30h until now, but fast around 30s in pass 30h
    I make sure winding the watch same as last 2 days, this is because the watch brand need use some day to run? I will keep use the watch, hope can have over 30h power
    I think the factory haven't test the watch before they send out to me?
    從我的iPad使用Tapatalk 發送
  7. #6
    Mar 2010
    There's always a final check at Stowa before a watch is delivered. However, during transport a lot can happen tomthe goods.
    Kind regards
    Mike
  8. #7
    Jul 2016
    The 4th test, the power can run around 42h and the error around 25s in this 42h, I think there are acceptable, my problem solved
  9. #8
    Jul 2016
    This is my stowa, thanks all
    raiusick likes this.
    Similar Threads
    1. Antea KS Power Problem
      By ByronD in forum Jörg Schauer & STOWA
      Last Post: June 16th, 2018, 18:42
    2. Power Reserve Problem
      By jw3571 in forum Breitling
      Last Post: November 22nd, 2015, 14:59
    3. Is my Antea KS mainspring dying? <24 hour power reserve
      By bomgd3 in forum Jörg Schauer & STOWA
      Last Post: March 26th, 2014, 22:01
    4. Problems with Antea power reserve
      By zura in forum Jörg Schauer & STOWA
      Last Post: July 18th, 2012, 22:56
    5. Power Reserve Problem
      By WillMK5 in forum Orient
      Last Post: January 5th, 2011, 05:06
