Parnis Power Reserve Seconds Dial hand not in sync with minutes hand
Thread: Parnis Power Reserve Seconds Dial hand not in sync with minutes hand
Results 1 to 4 of 4
    Oct 2012
    USA
    Got my first Parnis 43mm Power Reserve couple days ago. Beautiful watch with accurate time-keeping so far. However the seconds hand sometimes moves irregularly or no movement at all, but the minutes hand can still keep time accurately with the computer time. it seems like the seconds dial hand at 6 o'clock is totally not in sync with the watch movement, and not affect the time-keeping at all. Does it only have an aesthetic decoration function and no mechanical function at all? Any inputs from Parnis owners here?
    lvt
    lvt is offline
    Member lvt's Avatar
    Sep 2009
    The dark side of the Moon
    Re: Parnis Power Reserve Seconds Dial hand not in sync with minutes hand
    If sometimes the seconds hand has no movement at all there could be something loose inside, in some movement the small second dial is driven by an extra wheel.
    As long as the minutes hand is in sync with the hour hand I wouldn't worry too much, it's just aesthetic.
    Ball - Casio (G-shock) - HMT - Longines - Parnis - Seagull - Steinhart - Tissot - Victorinox - Yema
    Oct 2012
    USA
    Thanks for your suggestion. I'll keep an eye on it for couple more days and decide if I need replace it with the seller. It's really a pain to go through the international shipping process.
    Quote Originally Posted by lvt View Post
  4. Remove Advertisements
    WatchUSeek.com
    Advertisements
  5. #4
    Member mpalmer's Avatar
    Dec 2011
    Middle of the Middle West
    It's too bad you are having issues with it, it is an attractive looking watch.
    "The stuff that dreams are made of…" - RGM ‘801 EE Motor Barrel’
